Serpentine belt diagram and help
2014 NISSAN ALTIMA
123,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
UGAGIRL
I need the diagram for the car listed above's serpentine belt and any advice or how to on replacement. Thank you!
Jun 18, 2019 at 9:42 AM
Hi UGAGIRL,
Here is the procedure and the diagram of the belt routing. Please let me know if you need more information.
Jun 18, 2019 at 12:53 PM
MARINITO
Is the drive belt routing for 2010 nissan altima?
Sep 10, 2020 at 12:04 PM (Merged)
There are two different engine in this car so here are both diagrams and a guide to help you change the belt out below.
https://www.2carpros.com/articles/replace-serpentine-belt
PACHYAUTO63
  • 40 POSTS
I need a diagram on how to put the belt on.
Sep 10, 2020 at 12:05 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
Here is how you install the serpentine belt. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ASHLEYGS
Engine Mechanical problem 4 cyl Two Wheel Drive Automatic 106375 miles
I need the diagram for a 2005 Nissan Altima 2.5 S
Hello, Here is a guide to show you what you are in for when doing the job. https://www.2carpros.com/articles/replace-serpentine-belt
https://www.2carpros.com/forum/automotive_pictures/12900_db_3.jpg
https://www.2carpros.com/diagrams/nissan/altima/2004 Check out the diagrams int he link above Please let us know if you need anything else to get the problem fixed. Cheers, Ken
SPIROKINTA
how can i get a serpentine belt routing diagram?
below
CHAPLAIN D
2002 Nissan Altima 4 cyl Front Wheel Drive Automatic 96k miles
my serpertine belt is vibrating coming off the alt and making noise. when i lube it a little it stops so i m assuming that it needs changing what is the belt route and do i need to remove the top mount.
MHPAUTOS
  • 31,937 POSTS
Hi there, Belt set up as per pic, Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_16.jpg
