Adjustment
1. Loosen the mounting bolt "B" and lock bolt "C" and lower bracket mounting bolt "D". Remove belt if replacing.
2. Tighten the mounting bolt to the specification.
3. Turn the adjusting bolt "E" to obtain the proper belt tension, and retighten the lock bolt and lower bracket mounting bolt.
4. Recheck the belt tension.
5. If you installed a new belt, run the engine for 5 minutes. Readjust the belt to the used belt specification.
Nov 5, 2019 at 3:05 PM
(Merged)
