Serpentine Belt
1995 FORD THUNDERBIRD
100,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
TINAIZZAMAN
I need to change my serpentine belt, however, I lack a proper diagram and steps needed to remove and replace the belt. Can you please advise? The diagram would be very beneficial as well as certain tools needed. Thank you :)
Dec 23, 2016 at 4:51 PM
CARADIODOC
  • 34,306 POSTS
There should be a sticker under the hood that shows this. The tensioner pulley is spring-loaded. Hook a wrench or ratchet on the the bolt head or hole, and use that to remove the tension from the belt so it can be removed.
Dec 23, 2016 at 5:27 PM
JOHNNY G.JR
  • 320 POSTS
Most ford tensioners can be released with a half inch breaker bar,look for the square hole.
Dec 23, 2016 at 6:34 PM
