Serpentine belt replacement length?
2005 ACURA MDX
200,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
ALEC2
I want to know the length of the replacement serpentine belt i should get. I can remove and replace it however I would like to know the length and type.
Oct 25, 2024 at 12:38 PM
For a 2005 Acura MDX with a 3.5L V6 engine, the replacement serpentine belt specifications are as follows:
Length: Approximately 83.7 inches (2126 mm)
Part Number: Common part numbers vary by manufacturer:
Gates: K060827
Dayco: 5060827
ACDelco: 6K827
Bando: 6PK2105
Here is how to replace the serpentine belt in case you need it. Check out the images (below). Let us know if you need anything else.
Oct 25, 2024 at 5:54 PM
