Are you sure the compressor locked?
Or
Is the pulley bearings what are actually locked up.
I have not located any information for a belt to bypass with. Trial and error may be the only way to find one, you must insure the shorter belt does not interfere with other stuff in the new belt path.
Grabbing at straws here, as I cannot see your situation.
1) Turning on the A/C makes the clutch engage.
2) Turning on any "heat mode" that "defrost" is included in the setting (ex. feet/ face/ windshield). Turns on the clutch and compressor- Boom! There goes the dragging and the belt!
3) With an unplugged clutch, nothing can turn it on! The clutch will not engage the compressor (at all) and the pulley still be able to freewheel.
If the clutch pulley bearings are fine, all might be okay until you make replace the compressor.
Just trying to make it make make sense and maybe workable, maybe this option never entered as an option.
Your turn,
The Medic
Jul 7, 2018 at 12:14 PM
