I noticed the belt on my vehicle was getting cracks on the ribbed side so I changed the belt for a Gates belt. Ever since then every belt I put on has tore up with hardly no driving miles. I changed the tension pulley, the idle pulley, and the power steering pump. Still have the same problem. It doesn't matter if the A/C is on or not, it still does the same thing. I did change the thermostat in it a while back in which I had to remove the alternator to change the thermostat. The belt that was on it was getting old with cracks in it. That's why I changed it. Ever since I changed the belt I had this problem. The belt can be put on right, once the engine is started the belt rides almost against the front of the engine block. If the front bearing was going out the engine would make some kind of howling sound or a grinding noise which it's not. I need to get this repaired. It's my only source of transportation. I borrowed a car for a few days but I can't keep using someone else's vehicle. What do you think could be wrong with my vehicle?
Jul 17, 2021 at 4:38 PM
