what size or length of serpentine belt to bypass the power steering pump?
1992 DODGE CARAVAN
200,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
TOYMANS
My van goes to the dump if I can't do this, but my mechanic says it can be done and should work. I need to know what size or length of serpentine belt I would need if I was to bypass the power steering pump on my van listed above with A/C?
Dec 8, 2022 at 5:33 PM
SQM
  • 6,383 POSTS
To find out the size of the belt you will actually have to manually measure it. The catalog does not list the size needed when by-passing the power steering pump.
One of the best ways to measure it is to use a string and route the way the belt should go around the pulleys and simply measure it. Whatever length you measure, the belt needs to be just a little shorter to account for the tensioner being in the fully released position.
Let me know if you have any questions.
Thank you.
https://www.2carpros.com/articles/replace-serpentine-belt
Dec 8, 2022 at 10:31 PM
