Serpentine belt replacement diagram
2007 DODGE CALIBER
100,000 MILES
JOSEPH E
Need a diagram on how to replace a serpentine belt on the car listed above 20 engine.
Sep 8, 2018 at 12:11 PM
CJ MEDEVAC
  • 11,004 POSTS
Here is the serpentine belt routing diagrams to help you step by step with instructions in the diagrams below to show you how on your car. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 8, 2018 at 4:57 PM
BARBARA1963
  • 99 POSTS
I had to replace the alternator plus put a new battery because the alternator drained it, the car don't have a diagram on the car to put the serpentine belt back on and I didn't pay attention when I took it off,please send me the diagram please
Dec 18, 2020 at 9:58 AM (Merged)
CARADIODOC
  • 34,306 POSTS
Here's the diagram for your serpentine belt.. Its a good idea to draw it on a clean flat spot under the hood with a sharpie if the decal is missing. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ROSSRIZZO
Engine Mechanical problem
2007 Dodge Caliber 4 cyl Front Wheel Drive Automatic
where can i get a routing diagram for the drive belt car has a/c
DOCFIXIT
  • 18,828 POSTS
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_5.png
2CP-ARCHIVES
  • 4,540 POSTS
Can i replace clutch of ac compressor because it make a big noise and im check it and use another diagram of serpentine belt?
Dec 18, 2020 at 9:59 AM (Merged)
HMAC300
  • 48,601 POSTS
Here is the serpentine belt diagrams below with a guide that will help walk you through he steps of replacement.
https://www.2carpros.com/articles/replace-serpentine-belt
SHORNUF
I suspected the fan belt was going because of the noise, but when the mechanic ran a "diagnostic" on it they said it was the air compressor. Is there any relation between the two?
CH112063
  • 1,320 POSTS
Yes there definitely is. I'm sure your mechanic would rather it had not been the a/c compressor belt. He is correct. I am sorry you have this trouble. He will fix it with as little cost as possible I'm sure. The a/c is driven by the same pulley and if it is just the front it may not be too expensive. OK
NYYANKFAN
I need to know the exact name of the pulley #3and#8 so I can go to the store to buy it
Mar 18, 2025 at 12:19 PM
