Where are the camshaft position sensor and crankshaft sensors located?
2006 BUICK TERRAZA
137,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
DICK LITTLE
Need to know where the camshaft position sensor and crankshaft sensors are located on engine.
Nov 17, 2024 at 3:20 PM
The camshaft position sensor is located at the front of the engine, center, below the intake manifold. See pics 1 and 2 below.
The crankshaft position sensor is located at the rear of the engine close to the firewall. See pics 3 and 4.
Let me know if this helps or if you have questions.
joe
See pics below.
Nov 17, 2024 at 9:14 PM
DICK LITTLE
When I change these sensors do I need to use a scan tool to delete them off BCM?
Nov 18, 2024 at 4:10 PM
If you are referring to the diagnostic trouble codes, I would delete them to make sure they don't return. If you wait long enough, they could clear on their own, but it may take some time.
Nov 18, 2024 at 7:09 PM
