Well with those codes the problem isn't in any of the sensors, The sensors are working and telling the computer that there is a problem with the cam/crank timing. Basically the timing chains have stretched and that is changing the cam/crank timing enough to cause a problem. This is common with the newer multi chain engines because they use smaller chain. To repair it requires replacing the timing chains, tensioners and guides.
Jan 14, 2018 at 8:00 AM
