Damaged radiator causing engine to overheat
2003 NISSAN MARCH
80,000 MILES • 2WD • AUTOMATIC
RICH ISAAC
  • 11 POSTS
Greetings my car listed above k12 model. It's giving me some issues, it was loosing power when moving then the radiator got damaged. So I took it for diagnosis they said I need to buy throttle sensor, pedal sensor and temperature sensor. I got a pedal sensor and some one cleaned the throttle sensor and repaired the radiator but it moved for a day then when going a bit up hill it makes a funny sound and and shut off. Then the radiator got damaged again the temperature is high. how best can I solve this problem?
Jul 17, 2021 at 4:40 AM
SQM
  • 6,383 POSTS
Is your check engine light currently on?
If so do you know the codes?
I have attached a video showing how to retrieve the codes.
After you get the codes please let me know what they are and we will see what it might be.
https://youtu.be/vMwTzURWXmk
Thank you.
Jul 17, 2021 at 11:33 AM
RICH ISAAC
  • 11 POSTS
Yes it's always on.
Jul 17, 2021 at 11:41 AM
SQM
  • 6,383 POSTS
I think the good first step would be to scan the vehicle for the trouble codes. After you get the codes, please let me know what they are.
https://www.youtube.com/watch?v=b2IJGfImVvw
Thank you.
Jul 17, 2021 at 12:00 PM
RICH ISAAC
  • 11 POSTS
How are you? I have the car listed above k12 model I'm noticing oil on the throttle sensor is it normal and this throttle sensor has been giving me some problems and engine check light is always on.
Jul 25, 2021 at 1:50 PM
SQM
  • 6,383 POSTS
Are you talking about the throttle body? or the throttle position sensor?
Either way you should not have oil on it.
Can you upload a picture?
Also what are the codes for the engine light?
Thanks
Jul 26, 2021 at 5:47 PM
Hi Rich Isaac,
We need to keep each post to one topic so that others that have the same issue will be able to find them. They will not be able to find them under different topics.
So let us know what you find with checking for codes and then if you have another issue, let's get that started on a new post. Thanks.
Jul 27, 2021 at 12:35 PM
RICH ISAAC
  • 11 POSTS
How are you? I have a Nissan March k12 2003 model sometimes when I start it it makes a funny sound and switch off.
Aug 1, 2021 at 6:12 AM
SQM
  • 6,383 POSTS
Hey Rich,
If you would please open a new thread in the site. That way we will be able to better assist you.
Just go to this link to start a new question thread:
Thank you.
Aug 1, 2021 at 10:39 AM
