I had new tires put on the vehicle and when i drove it the ABS light came on. Immediately after the service engine light came on. The vehicle then felt as if i put it in neutral and was accelerating then it would jerk into gear. A scanner shop i was sent to by Discount Tire said the sensors were tested and were fine. I asked him for the codes and i was told 0035, 0036, 0037, and p0502.
Unfortunately i didn't have the financial means to have anyone diagnose the actual problem so it sat. I did some research and figured i would have to start somewhere so i bought a speed sensor from Amazon and had a new neighbor replace it. When i test drove it it felt okay at first until i accelerated quickly while making a left turn. It didn't feel like it jerked into gear it felt more like a jumping feeling. I know there are 4 wheel speed sensors. I have located the 2 on the front. Well actually the harnesses. The rear ones i haven’t really looked bit didn't see anything obvious like the front. If you would please advise me of the proper steps i should be taking to get this problem fixed. I will go get photos now to send. Thanks so very much
Oct 25, 2019 at 2:29 PM
