Welcome back:
It comes as a unit. Here are the directions for replacement. The attached pics correlate with the directions.
__________________________________________________________
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
fuel pressure regulator
32
Community 17 Create Quote
2014 Ford Fusion FWD L4-1.5L Turbo
High-Pressure Fuel Pump
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Service and Repair Removal and Replacement High-Pressure Fuel Pump
HIGH-PRESSURE FUEL PUMP
Materials
pic 1
Removal
NOTICE: Do not loosen any fittings or plugs on the high-pressure fuel pump.
1. Refer to: Fuel System Pressure Release See: Fuel Pressure Release > Procedures > Fuel System Pressure Release (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
2. Refer to: Battery Disconnect and Connect See: Battery > Procedures > Battery Disconnect and Connect (414-01 Battery, Mounting and Cables, General Procedures).
3.
1. Refer to: Spring Lock Couplings See: Fuel Line Coupler > Procedures > Spring Lock Couplings (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
pic 2
4. NOTICE: To release the fuel pressure in the high pressure fuel tube, wrap the high-pressure fuel pump flare nut with a shop towel to absorb any residual fuel pressure during the loosening of high-pressure fuel pump flare nut.
pic 3
5. NOTE: Alternately loosen the 2 high-pressure fuel pump bolts one complete revolution at a time.
pic 4
6.
pic 5
7. If any flat spots or scoring are found, especially in the indicated areas, then inspect the high-pressure fuel pump and the high-pressure fuel pump tappet drive lobe. Install new components as necessary.
pic 6
Installation
1. NOTE: The cam lobe for the high-pressure fuel pump must be at BDC (bottom dead center) for the high-pressure fuel pump installation.
pic 7
2. NOTICE: Only rotate the crankshaft Clockwise (CW) or damage to the engine may occur.
pic 8
3. Material : Motorcraft(R) SAE 5W-20 Premium Synthetic Blend Motor Oil (U.S.)/ XO-5W20-QSP (U.S.) (WSS-M2C945-A)
pic 9
4. Make sure that a new high-pressure fuel pump O-ring is installed.
pic 10
5. NOTE: Make sure that 2 new high-pressure fuel pump mounting bolts are installed.
1. Install the high-pressure fuel pump and loosely install the 2 high-pressure fuel pump bolts, alternately tighten each bolt 90° at a time in turn until the torque is achieved
Torque : 80 lb.in (9 Nm)
pic 11
6. NOTE: Only tighten the 2 high pressure fuel tube flare nuts finger tight at this stage.
NOTE: Make sure that a new high pressure fuel tube is installed.
NOTE: Calculate the correct torque wrench setting for the following torque using the Torque Wrench Adapter Formulas.
Torque :
Stage 1: 15 lb.ft (21 Nm)
Stage 2: Wait 5min
Stage 3: 15 lb.ft (21 Nm)
pic 12
7.
pic 13
8. Refer to: Battery Disconnect and Connect See: Battery > Procedures > Battery Disconnect and Connect (414-01 Battery, Mounting and Cables, General Procedures).
9. Refer to: Fuel System Pressure Release See: Fuel Pressure Release > Procedures > Fuel System Pressure Release (310-00A Fuel System - General Information - 1.5L EcoBoost (118kW/160PS), General Procedures).
Let me know if this helps.
Sep 25, 2019 at 6:20 PM
