Seiko Automatic Transmission
2004 ISUZU NPR
300 MILES
ALDRED20
Truck wont take off in drive (D). Only In first (1) once the truck takes off in first and i shift to 2nd or (D) it runs perfect with no problems or noises.
when i get to a complete stop i have to repeat that process again!
I have checked the fluid level and its good, i also changed the transmission filters the one inside and out. When changed the inside filter i checked for broken pieces or any that could cause the problem but the fluid was clean, dirty but clean.
and i also notice that the (D) light on the dashboard doesn't turn on when its in drive. all of the others do.
would the valve body or solenoids cause this problem?? or any other transmission sensor?
can you please help?? thank you!
May 3, 2013 at 11:05 AM
HMAC300
  • 48,601 POSTS
have a trans guy scan for codes, you said fluid was dirty if it was black or dak brown something burned up in trans.
May 3, 2013 at 12:11 PM
EMGN8ION
Cause: likely blown trans. fuse. (can be other power or failed Tcm problems) Isuzu truck strong and GM hide the fuse: remove glove box and look to the left, wrapped up in harness are two fuses. one is for the transmission Tcm power. you may notice that the o/d cancel light and trans lights do not work without power.
Here is a guide to help you
Aug 1, 2017 at 3:19 PM
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Aug 2, 2017 at 4:45 PM
