While driving at low speeds or slowing down and taking corners the truck seems to be shifting in and out of 4wd. The whole truck will jolt very hard intermittently.
What I know currently:
Fluid was just changed, reddish brown fluid came out and the transmission fluid was changed a month prior so I know they have not been mixing due to a blown seal. Problem only occurs when accelerating. If in neutral moving forward problem does not occur. Transfer case shifter is not loose and shifts into all gears (2L-4H-N-4L). Shifter linkages are tight and appear to have no damage. No check engine light. With vehicle on jack stands problem does not occur. Front and rear driveshafts do not spin freely without turning the wheels when in 2L.
My troubleshooting has led me to believe: 1. Internals of transfer case are broken (what would be broken I do not know). 2. Front axle is broken internally.
Nov 25, 2018 at 3:44 PM
