Just recently my car has been doing the following, but only on occasion:
1. When I turn the key to the ON position, the normal functions activate as expected, but when I turn the key to start the car, nothing happens. No sound, no attempt to start, nothing.
2. While the key is in the ON position but the car is unable to start, three warning lights appear on the dash. The anti-slip/hydroplane light, the ABS light, and the red 'BRAKE' light.
3. Then, after I try starting the car a few times, eventually the car reacts to me turning the key and the car starts. I do not know why the car won't start sometimes and sometimes it does. I don't change anything that I am aware of.
4. However, when the car starts, the three dash lights mentioned earlier are still on, the vents blow air but the A/C doesn't work, and the gear indicator on the dashboard (PRND) does not respond to me shifting gears. So, I am able to shift to reverse or drive and the transmission functions correctly, but the lights on the dashboard do not reflect this change. The gear indicator remains on 'Park'.
5. Then, if I begin to drive the vehicle with all the aforementioned problems, soon I get a dashboard warning saying 'Service Brake Assist'
6. Soon after the 'Service Brake Assist' light goes away, then the following things occur:
- The door locks engage
- The A/C begins working
- The dash lights go away
- The gear indicator updates and correctly shows which gear the vehicle is in
Then the vehicle drives normally for the duration of the trip. However, the next time I start the car, the same problem may or may not recur. Are you able to help me with this problem?
Jul 20, 2025 at 8:20 PM
