Okay. if the theft system is on or flashing then that is preventing the start.
I assume you are using the remote to unlock it and it does not work? What about unlocking the door with the key? If that doesn't work then we may just have an issue with the door circuit so here is testing. However, I would start with checking for codes because if there is an issue with the system it should have a code.
Let us know what you find with this and we can go from there. Thanks
Sep 6, 2021 at 6:15 AM
