My Mach 1 was put into storage while I was away on a job assignment.
A friend thought he would be helpful and removed the ignition and then lost it.
Someone else got to my car and they cut the battery cables out stole the battery and attempted to remove the sub-woofer from trunk that had been professionally installed. They also got both amps from behind the seats.
My problem is, I am thinking with the security system. I am not able to use my windshield wipers because when I have the fuse in the door beep alarm will not go off. Also, the overhead light also does not work anymore.
The key fob will not lock or unlock my car nor will it set the alarm. Only the dash light blinks. I had to buy a new ignition cylinder from AutoZone.
Tell me there is a way to save the patient?
Jul 16, 2018 at 12:20 PM
