Security light permanently on?
2000 CHEVROLET BLAZER
190,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
KROJO
Brake booster was replaced at mechanic shop, drove around a while before heading home no issues. Next morning the security light was on, and it hasn't turned off since. Relearn process has been done more than 15x, ignition cylinder replaced, all fuses are good, new battery. I just now received a (PLJX GM self-learning Pass lock Override module from Directed) via FedEx.
Could someone please help!
If any step-by-step wiring installation with pics. Would be more than appreciated.
Aug 20, 2024 at 8:10 PM
The kit should have come with instructions, I have not heard of such a kit, so I am not sure what you need? So, does the security light flash or is it on steady while you drive?
This guide might be able to help:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
This is a hard system reboot guide which can help reset the systems and give you a fresh start.
Aug 21, 2024 at 10:16 AM
