This is a pass-key system. If the light is staying on solid, it is likely a hard failure in the system that will have to be repaired. This is a pretty basic system that has its own security module that cannot be bypassed. You can bypass the key sensor if you wish but you would still need an operational module for the car to run. If you want to bypass the sensor, just measure the resistance of the pellet and by a resister of the same value and solder it between the two small white wires going to the sensor.
You will likely end up needing to replace the module. You cannot put a used module in it as they are programmed to the previous car. A new module is sold in "learn mode" so it will learn the key value in the first start attempt.
Oct 14, 2017 at 11:37 AM
