We need to start with checking for codes. Clearly the vehicle thinks it is trying to be stolen so it has entered a theft event.
What repair to the engine did you do? Was the battery unhooked when you did this? If so that was the cause. Sometimes when you unhook the battery and then reconnect it the theft system thinks someone is trying to steal the vehicle. Usually unlocking the vehicle with the key fob will deactivate it. Do you have a fob? If not, try unlocking the driver door with the key and see if that turns the system off. If not, we may need a scan tool that can go in and turn this off.
Unfortunately we don't have a manual on this vehicle and don't offer a similar one here in the USA so we can't provide specifics about the system but I am sure we can figure something out. Thanks
Nov 11, 2020 at 6:17 AM
