The security indicator light started flashing . The car is running fine. The light has not stopped flashing all day.
Dec 24, 2017 at 6:50 PM
CERTIFIED EXPERT
Can you try exiting the car and using the lock fob to lock it then let it sit for 45 minutes and then unlock it. This should disarm the system and the light will stop blinking.
Dec 26, 2017 at 2:31 PM
DEBBIE2017
MEMBER
That didn't work. It's still blinking. I've tried locking and unlocking the car by putting the key in the driver's side lock rather than using the lock fob to reset it. That didn't work either. I don't know what it is but I'm afraid to drive it because I'm worried that it will decide not to start.
Dec 26, 2017 at 5:50 PM
CERTIFIED EXPERT
Yep let's try one more thing. Please remove the negative battery cable and touch it to the positive terminal for 5 minutes this will hard reboot the system and reset the protocol.
Dec 26, 2017 at 7:22 PM
DEBBIE2017
MEMBER
That might be a little more than I can handle
Dec 27, 2017 at 3:49 PM
CERTIFIED EXPERT
Do you have an extra key for the car can you try that? If that doesn't work then you have to take it to the dealer for reprogramming.
Dec 28, 2017 at 11:11 AM
DEBBIE2017
MEMBER
I do have an extra key I already tried that and it didn't work. I took it to the dealer this morning they reprogrammed it and it took care of the problem.
Dec 29, 2017 at 9:08 AM
CERTIFIED EXPERT
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help. Happy new year!
