Security light stays on solid and code p0513
2004 DODGE CARAVAN
136,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JOHN WAGNER
Will not crank over by key, and the security light stays on solid, dash showing code p0513.
Feb 16, 2020 at 3:07 PM
Good evening,
You will need an advanced scan tool to access the security section of the ECM. You will need to see if the Skim code is correct. You may have to contact the dealer to verify and then compare.
I attached a flow chart for you to follow.
Feb 16, 2020 at 4:19 PM
JOHN WAGNER
Very well appreciated, I've fought this problem for weeks, I put in a new switch and key, ECM or whichever control box is behind the headlight that matches the key and switch, doors locked and unlock by the remote key? I want to find the problem, and sell it at this point. Thanks. Hope you have better luck with figuring it out than me.
Feb 17, 2020 at 2:00 PM
You are welcome.
Always glad to help.
Feb 18, 2020 at 2:26 AM
