How do you reset security after replacing lock cylinder and ignition?
Mar 11, 2020 at 5:26 PM
STEVE W.
CERTIFIED EXPERT
Because you have changed the lock cylinder itself you need to use a dealer level scan tool to program in the replacement keys into the PATS hardware. The procedure that used the original keys to program a new key will not work as you need to be able to turn the ignition on and off with the key during the process and with a different key cut you cannot do that.
Mar 12, 2020 at 1:19 AM
BMDOUBLE
CERTIFIED EXPERT
No programming is necessary if just the ignition lock cylinder is replaced, unless you are replacing it because you want a new set of keys due to theft, new owner, etc.
