Got in to start, ran for 2 seconds and shut off. Attempted a second time and got the same result. Third attempt resulted in no crank, no start with flashing security light that will not go out.
Fixes attempted so far:
1. Removed and hard reset TIPM (removed both battery terminals and zip tied together and removed TIPM overnight.
2. Checked relay and relay box for corrosion.
3. Turned key to on position left for 10 minutes, turned off (leaving key in ignition) waited 30 seconds. doing this 3 times.
Everything turns on, battery was tested, starter tested, fuses checked, wiring looked over for wear, can hear the fuel pomp engage, fob works..
Can someone point me in a direction?
Oct 28, 2019 at 3:31 PM
