trying to hook up vacuum lines to electic air controle pump
Apr 20, 2014 at 6:22 AM
CERTIFIED EXPERT
hello my name is roy and I will assist
there is am electrical connector for power, an inlet line for air and an outlet line for air to a check valve and then that goes to the exhayst manifold. the check valve should have 1 vacuum line attached that is manifold vacuum from the intake manifold.
