Second key will not turn in the ignition?
2010 BMW X3
105,000 MILES • AUTOMATIC
BOLIOSIS2005
I lost my original key, but I had a backup key. I have recharged the battery in key, but the key will not turn in the ignition. I’m sure nothing is wrong with the ignition because my original key had no problems. Please help!
Mar 31, 2025 at 1:07 PM
STEVE W.
  • 15,113 POSTS
First test, Try the key in the other locks on the car. Does it work in them? If it works in those try pushing the key in then gently pull it back while trying to turn it, it may be cut wrong or it might not fit your vehicle. If you cannot get it to work you will want to visit a dealership, normally if you can give them the VIN and prove that you own the car, they can get the code to cut a new one. A mobile locksmith can usually do that as well.
Mar 31, 2025 at 1:41 PM
