seat belt does not retract
2000 VOLVO S70
130,000 MILES • 2.4L • 5 CYL • TURBO • 2WD • AUTOMATIC
KRAMERDAD
seat belt on driver's side will not retract.
Feb 23, 2018 at 8:20 AM
Can you look to see if the belt is folded over on itself? If not the re-tractor will need to be replaced. Here is a guide to show you what you are in for when doing the job.
Check out the diagrams (below).
Feb 24, 2018 at 12:22 PM
KRAMERDAD
Thanks so much Ken, ten minutes after viewing the informative you sent my problem was solved.
Feb 24, 2018 at 4:25 PM
Good to hear, please use 2CarPros anytime we are here to help.
Feb 26, 2018 at 11:33 AM
