Hi, I recently bought the car listed above 1.5 dCi. The only problem I have is the seat belt alarm was going off even when seat belts were fastened. I bought seat belt alarm stoppers off eBay which you connect into the seat belt holder. I put them in. One in drivers seat one in passengers seat.. and drove the car and great.. no annoying alarm..then when I had a passenger the alarm goes off again. .so the drivers seat is fixed but the passengers is not. I took the seat belt holder apart and separated two wires which were touching which I assumed was the alarm wires. that didn't work. looked under the seat saw that a wire had been cut by the previous owner. so I rejoined them. Still didn't work. took all the sensors out from under the seat. still didn't work. disconnected two plastic connections under the seat and it worked. no alarm. But a warning sign comes up on the dash.. airbag not working. the alarm is so annoying I am tempted to drive it with the airbag not working. If anyone has any suggestions how to stop the alarm I would be very grateful. Thanks
Apr 10, 2019 at 11:51 AM
