Seal sunroof and moon-roof leaking
2008 BUICK ENCLAVE
121,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
CORY2427
  • 293 POSTS
Keeps having water in different spot when it rains. I got headliner out and everything just need advice on how to seal both off completely got a tube of 3m window weld to do it.
Nov 24, 2019 at 9:53 AM
Before doing that, the most common cause of them to leak is due to a plugged draining system. I would suggest inspecting and cleaning the drain to see if that takes care of the problem first before you apply a sealant. Chances are that is the cause.
Here are the directions for the procedure. Try this first. It's free to do. LOL
Sunroof Drain Inspection and Cleaning
Vehicle Body and Frame Roof and Associated Components Sunroof / Moonroof Sunroof / Moonroof Drain Service and Repair Procedures Sunroof Drain Inspection and Cleaning
SUNROOF DRAIN INSPECTION AND CLEANING
Drain Hose Routing
A drain trough encircles the sunroof window panel and water is drained off by the hoses located at each corner of the housing. A drain channel spans across the sunroof module at the rear of the window panel and directs water into the trough.
1. Ensure that the front drain hoses are routed down the windshield pillars and out the center of the front pillar between the door hinges. Ensure that the hoses are not kinked. Replace any torn or cracked hose.
2. Ensure that the rear drain hoses are routed through the rear pillars and out of the rear lower quarter panel. Ensure that the rear hoses are properly routed in the metal roof slot and are attached in place. Replace any torn or cracked hose.
Plugged Drain Hose
If a waterleak has occurred, inspect for a plugged drain hose at each corner of the drainage system:
1. Open the sunroof window.
2. To test for blockage, pour a small container of water into the module housing drain trough. Inspect each corner to confirm the drain hose is draining water.
Caution: Wear safety glasses in order to avoid eye damage.
3. Use compressed air, 35 psi or less, to blow out any drain hose that is plugged.
4. Test the system again.
5. If the hose remains plugged, inspect for improper routing or kinks. Refer to Drain Hose Routing above.
6. Remove any hoses that remain plugged.
7. Remove the blockage:
1. Push a mechanics wire through the hose to remove the obstruction.
2. Use compressed air in order to blow out any remaining material.
8. Reinstall the hose.
Disconnected Drain Hose
Inspect the drainage system for disconnected drain hoses. Complete the following steps in order to obtain partial access to drain hoses and inspect for a disconnected hose.
1. Open the sunroof window panel.
2. It is only necessary to lower the headliner. Only do those step in headliner replacement that will lower the headliner enough to gain access to the part. Refer to Headlining Trim Panel Replacement.
3. Connect any disconnected hoses.
4. Ensure that the rear drain hoses are properly routed in the metal roof slot and attached in place.
Let me know if I can help.
Nov 25, 2019 at 7:58 PM
CORY2427
  • 293 POSTS
It’s not that been through the whole process even had it in body shop 4 days couldn’t find out exactly where water coming in at. just said sunroof does take on more water than it should. so I just took window weld and sealed outside sunroof and moon-roof should keep water out. thanks anyway.
Nov 25, 2019 at 8:12 PM
CORY2427
  • 293 POSTS
How do I get roof rails off? does that require leaving headliner down?
Nov 26, 2019 at 6:51 AM
Okay. Most times it is nothing more than a plugged drain. When you say roof rails, what exactly are you referring to? Do you mean the luggage rack on the exterior of the vehicle? If so, yes. The headliner needs to stay down to access the bolts. Can you upload a picture for me to see?
Nov 26, 2019 at 4:54 PM
