Not a lot of fun. Basically it is bolted to the back of the instrument panel. To remove it you have to disconnect the bag using the connector behind the glove compartment. Then remove the dash, flip it over and unbolt the SRS module. Bolt the new one in place and reverse the process to install the new one.
What is the problem with the one you have? Testing faulty or throwing a code?
Sep 9, 2017 at 5:47 PM
