I have the SDM module in my hand but I cannot remove the connector from it, is there a trick to getting this off.
May 25, 2017 at 2:18 PM
HMAC300
CERTIFIED EXPERT
it may have a clamping lock on it which you pull up on it it locks down when you pull up it will unlock or should then the connector can come out.
May 25, 2017 at 4:01 PM
JEFFELECTRIC
MEMBER
It has a black tab that I pulled out but still cannot remove the connector. It also has two plastic tabs on the side of the connector that I lift up with still no luck.
May 25, 2017 at 6:18 PM
HMAC300
CERTIFIED EXPERT
take a picture and send it maybe I can help you out
