Hi windrider10?
Thank you for the donation.
If you are able to able to turn the ignition to ON, chack if the P indicator light is showing. If not, then the Park Neutral position switch coudl be faulty or out of adjustment resulting in the key being stuck and cannot be turned to the LOCK position to be removed.
It could be the the key interlock cable adjustment at the steering column.
Jul 23, 2010 at 9:58 AM
