Engine makes a bad dry bearing noise on and off.
Turning on a/c makes no change. (with belt off) I pulled out gen.-bearing feels fine. I turned the waterpump pulley seems smooth and free. I turned the a/c pulley and it has a drag. but smooth?
1 should a/c pulley be free to spin?
2 do I have to remove comp. to repair bearing and or clutch?
3 is the clutch assembly or bearing replaceable?
4 can this be done while comp.is hooked up?
--hard to get at a/c unit. Thanks! Frank Graney
Aug 3, 2009 at 8:25 AM
