2005 Scion tC Hesitats at idle and when i decelerate
2005 SCION TC
59,000 MILES • 4 CYL • FWD • MANUAL
BTPORTER213
my car kinda chugs at idle and when it is decelerating.. my check engine light is on and it says failure in my front oxygen sensor.. would my oxygen sensor cause this.. i also want to note that i am getting terrible gas mileage now also?? any info would help thank you much bj porter
Dec 4, 2008 at 6:14 AM
KHLOW2008
  • 41,814 POSTS
Hi bj porter,
Thank you for the donation.
Yes, a failed O2 sensor can cause bad idling and very poor mileage.
However I would suggest checking the spark plugs as well.
I would like to know the exact error code that you got for the the O2 sensor. Sometimes the O2 sensor shows a code because of other influences, eg, running lean or rich
Dec 4, 2008 at 6:53 AM
BTPORTER213
i cant remember the exact code but it did say it was running lean
Dec 4, 2008 at 7:50 AM
KHLOW2008
  • 41,814 POSTS
Hi bj porter,
When engine is running lean, possible causes are
1. Faulty O2 sensor.
2. leaking vacumn
3. Clogged fuel filter
4. Faulty fuel pressure regulator, weak fuel pump.
5. Throttle position sensor out of calibration.
Dec 4, 2008 at 8:41 AM
BTPORTER213
whats your take on these universal O2 sensors or should i just pony up and get the $185 bosch brand thank you so much for your help
Dec 4, 2008 at 8:53 AM
KHLOW2008
  • 41,814 POSTS
Hi bj porter,
So far I have not known of any complications for Scions using universal O2 sensors, so I guess it should be ok to use it.
Dec 5, 2008 at 7:30 AM
