Thank you for that schematic of the steering rack. I definitely plan to check out the connections down there on each of the connectors.
Having said that, I am still looking for the pinouts of the two connectors on the “steering column control module”, what VW calls J527, and in my case, model 1K0-953-549-AJ.
This is the controller that sits under the column just behind the steering wheel. I’m interested in the two connectors on the back of that: The black 20 pin and the yellow 4-pin. The 4-pin is pretty much for the driver’s air bag, and of more interest is the 20-pin. The two large blades there are going to be +12 and ground, but the remaining 18 pins are what I need to trace, wherever they go.
I appreciate the work you guys are doing. If I may ask, where do you get your excellent color schematics from? If you’d rather not say, fine, but they are great.
Thanks again for your help,
John
Apr 7, 2025 at 7:08 PM
