Has had a crank no start, intermittent. Check engine light is on.Immobilizer light is on when running.
Oct 4, 2018 at 7:31 PM
DANNY L
CERTIFIED EXPERT
Hello, I am Danny.
Does the scanner not connect physically or does it light up and say there is No Communication to the vehicle? I have attached a few tutorials for you to view. Hope this helps and hope to hear from back from you soon. Thanks for using 2CarPros.
Danny-
Obd 2 Scanner connects via Kia adapter and lights up, tries to connect but cannot.
Oct 6, 2018 at 9:26 PM
DANNY L
CERTIFIED EXPERT
Hello again
What kind of Scanner? Does it just say "No Communication" ?
Danny-
Oct 6, 2018 at 10:29 PM
DENIS PATTI
MEMBER
Austel MaxiScan MS309. Yes says no communication.
Oct 7, 2018 at 10:50 AM
CERTIFIED EXPERT
If I can jump in here this is the wiring diagrams for the ALDL and a guide to help you test it. Make sure the ALDL is getting power from the fuel injector fuse 30 amp.
