Do you have codes in the other modules? If you can communicate with the other modules then you should be able to pull other codes. If you cannot then we may have a bus network issue.
Here is guide that talks about this CAN network:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
I would expect that we have loss of communication codes in the other modules that say they cannot communicate with the ECM. However, if the vehicle starts and runs and you have none of these codes then I suspect we have a scan tool or wiring issue.
So if this vehicle starts and runs, let's stop by a parts store and ask them to scan it. If we have two scanners that cannot communicate with the ECM then we can chase down a wiring issue.
At that point, I need you to get the voltage on pin 6 of the DLC and then get the voltage on pin 14 as well.
Let's start with this and go from there. Below is the wiring diagram for this. Thanks
Jan 31, 2021 at 4:19 PM
