What would cause my engine to not start?
2014 TOYOTA CAMRY
62,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ISHAMCH
What would cause my engine to not start? starter works but will not start.
Nov 22, 2017 at 11:29 AM
A problem with the mass air flow sensor will make it not start if okay it sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Nov 22, 2017 at 4:19 PM
