saturntech:top end oil leakage 98 saturn sl2
1998 SATURN SL2
160,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
FIXITMR
  • 9,990 POSTS
someone already put the felpro blue not sure how far\bak a few yrs i think. do they go bad like shrink i just did a starter and noticed oil up on manifold runners and all the way down engine also on crank pulley side and car leaks on ground i pulled topcover and i see it's the same gasket set i am about to use and it dont look bad actually. the spark plug hole far\ left has a little oil sitting. is this felpro replacement any good? would silicone help? there's 4 block sensors around starter but none of them looked like leakers. i hate doin work and no improvement!
Jun 16, 2014 at 6:09 PM
SATURNTECH9
  • 30,869 POSTS
I put a felpro one on my 1999 sl2 it worked well the gaskets do compress and leak over time.You must put a bead of silicone across both T joints where the front cover meets the head or you will have a leak right away.
Jun 16, 2014 at 7:38 PM
FIXITMR
  • 9,990 POSTS
seems like a weird design no actual pressure from bolts on cover i guess i could understand it with a plastic cover? ford (better idea) tempo tried same route with an aluminum cover what a mess! japs used o ring with aluminum and solid bolt down i think that is best simplest design! with this LOOSE?FLOATING approach i can see seepage is getting past gasket i wonder if high mileage blowby is also not helping with seepage? and what do you mean by t-joint?
Jun 17, 2014 at 12:48 AM
FIXITMR
  • 9,990 POSTS
ok i reread and checked car and see there was some silicone applied to the cover joint before.
Jun 17, 2014 at 9:33 AM
FIXITMR
  • 9,990 POSTS
i am also thinking the design of the gasket is faulty? there is this raised ridge on the head contact area that i think should be a slot/groove instead. i wonder if any experimentation was done on the design originally? the auto industry has become such an BUY IT and TRY IT HYPE monster driven by BENJAMINS!?
Jun 17, 2014 at 11:06 AM
SATURNTECH9
  • 30,869 POSTS
Please post a pic of the area your asking about not being flat.
Jun 17, 2014 at 12:06 PM
