My 2005 saturn vue has been somewhat stiff when shifting for about 5000 miles now. Today when I was driving home, I went to shift into 4th gear and it made a grinding noise and wouldn't shift into it at all. I drove a little further in fifth gear which worked fine. I stopped at a light and started to accellerate when 2nd gear went out....and then 3rd went out. I stopped and tried to put it in reverse and reverse was out too!!! First and fifth work fine though. Every time I try putting it in another gear, it's like shifting into neutral, but with a slight grinding sound. I don't think my gears or clutch are bad though as those would be things that get progressively worse. Could it be just a bad shift cable? And if so, is it an easy part to fix for an at home mechanic? Any help would be greatly appreciated!
Feb 10, 2010 at 1:27 AM
