2004 Saturn Vue Valve Noise
2004 SATURN VUE
84,000 MILES • 6 CYL • AWD • AUTOMATIC
IBECRUISIN
My wife's 2004 Saturn Vue with the Honda VTEC L66 engine idles rough, and has valve noise at low speed. Once I step down on the accelerator, it smooths out and the noise goes away, but when I let up on the accelerator, the valve noise comes back. (It sounds like a diesel) The performance under acceleration is not affected, and it is as peppy as ever.
We've had it to Saturn, and had the valves adjusted at an independent shop, but the noise is still there. They now claim it needs new motor mounts and it's just a vibration. $1500 dollars later, same noise. I'm worried that's it's going to ruin the engine.
As this is a VTEC, could that have something to do with the noise? As no one seems to be able to fix the problem, is it something I could do?
Jan 13, 2009 at 5:31 PM
MERLIN2021
  • 17,250 POSTS
Is the service engine soo light on? if not, could the noise be the fuel injectors and not the lifters? If it is on, get the codes read and we can investigate further.
Jan 13, 2009 at 6:00 PM
IBECRUISIN
The service light is not on. I tried injector cleaner
Jan 13, 2009 at 6:40 PM
MERLIN2021
  • 17,250 POSTS
Lifter and injector noise are different, can you say wich is making th noise?
Jan 19, 2009 at 12:11 PM
