P1791
2003 SATURN VUE
SCHILS1
Transmission problem 6 cyl All Wheel Drive Automatic
Transmission Control Module Loop code? Is this a relay problem or a sensor problem and how do I repair it?
Jul 2, 2009 at 4:24 PM
BRIAN 1
  • 1,030 POSTS
The instrument panel/body inline connector,located behind the left hinge pillar garnish molding, may have bent or corroded terminals.
https://www.2carpros.com/forum/automotive_pictures/147643_connector_1.jpg
check this first,and post back with what you find.
Jul 2, 2009 at 5:57 PM
ANDREW03
Where is this?
Nov 10, 2017 at 9:51 AM
This code is for the transmission input and output speed sensors. Here is a video that show the speed sensors being done.
https://youtu.be/f3bETtCIdxM
Different car but you get the idea.
You can run the codes by follow this guide.
Here is how you do it on your car. (below)
Nov 13, 2017 at 1:40 PM
