Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
Vue
Drivetrain
Wheel Bearing
Replace/Remove
2003 Saturn Vue how to replace rear wheel bearings
2003 SATURN VUE
70,000 MILES • 6 CYL • AWD • AUTOMATIC
UMPBOB
MEMBER
1 POST
FOLLOW
rear bearing loose and making noise do i replace just the bearing or the whole unit
Aug 20, 2008 at 1:10 AM
SERVICE WRITER
CERTIFIED EXPERT
Replace it with a timkin.
This is the only brand that I like to use, too many problems witht he other ones and it has a lifetime warranty.
The hub is held on by 4 bolts from the rear.
The axle nut spec MUST be torqued down to spec, or you'll ruin the bearing.
Aug 20, 2008 at 5:36 AM
