2002 Saturn Vue Turn signals stop, require engine restart
2002 SATURN VUE
64,300 MILES • 4 CYL • FWD • MANUAL
FOXCOLE
Last October I bought a 2002 Saturn Vue 2.2 L 4 cyl manual transmission, with 51,000 miles on it. I noticed some clicking in the steering column during turns. A month later, the turn signals began to stop blinking without notice, mid-blink or mid-turn or just not blink at all. When this happens, both left and right signals are affected. Hazards work fine, everything in the steering column works fine while the turn signals don't work.
The signals can be 'reset' by turning the engine off and on again. At first, the problem happened only occasionally but now is occurring more and more frequently... in fact, now they don't work more often than do. I replaced the blinker fuse, just in case that might help (though I didn't expect it to, and I was right).
What can be causing this? Is it something I can fix myself? (I'm sorry I can't donate more. I have been unemployed for a year and am on a strict budget.)
Aug 9, 2010 at 9:02 AM
KHLOW2008
  • 41,814 POSTS
Hi foxcole,
Thank you for the donation.
For the turn signal wiring circuit, there is nothing that can cause the problems indicated except the hazard switch.
I would suggest checking that out.
Aug 9, 2010 at 12:47 PM
