2001 Saturn SW2 Ignition Switch???
2001 SATURN SW2
101,000 MILES • 4 CYL • FWD • AUTOMATIC
SARAFACE
  • 4 POSTS
A week ago, my car wouldn't start after driving it somewhere. It would start up fine, run and then after I turned it off, it wouldn't turn over again until the car cooled down. I replaced the ignition switch and it worked for a week. Now, it's doing it again. It's not the starter, I've had it tested. What else can it be??
Nov 12, 2009 at 4:42 PM
It could be several things. We need to eliminate a couple things first. When it doesn't start, I need to know if you are getting spark and fuel to the engine. Here are written directions and a video to explaine how to check for both. Chances are the engine will be missing spark or fuel pressure. From there, I can further direct you.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
PS: Is the security light flashing or staying on?
Nov 12, 2009 at 8:39 PM
SARAFACE
  • 4 POSTS
The security light is not flashing. When I turn the key, I hear a click. For a second after, I hear some clicking under the dashboard on the passenger side. All of the lights come on, everything else is operational, except the engine won't start. The funny thing is, I got it started after about 30 minutes and it hasn't had a hiccup since then. I let it idle for 5 minutes and drove it 10 miles to work and when I turned it off and back on again, it cranked right up.
Also- the check engine light is on. I wasn't given a code when I had it checked, but I was told it was a pvc valve. Maybe, this could be related?
Nov 12, 2009 at 11:00 PM
Actually, the two are not related. THey are two different components.
Based on your description, I would start at the battery. First, make sure the battery terminals are clean and tight. Also, check the ground wire going to the engine block. Make sure it is clean and tight too. Also, make sure the terminal going to the starter it good also.
If all is good, my next guess is a starter relay getting ready to go bad or the solenoid on the starter is going bad.
Let me know if it happens again. If it does, I need you to have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should have 12+ volts. If you do, the starter is the problem. If there is less, let me know.
Nov 13, 2009 at 6:39 AM
SARAFACE
  • 4 POSTS
thank you so much, I've made a list of the possible problems and I will take them to my mechanic/ good friend who works on my car for free (<3333) and ask him to go over all of it with me.
It still hasn't given me a problem since that one instance. (which still baffles me, because it had only been driven one block before being turned off)
If it does start up again, I will be back! (with more $$ to donate, of course!)
Thanks again!
Nov 13, 2009 at 11:28 AM
Not a problem. Let me know how things go or if you have other questions.
Thanks for using 2carpros.com,
Nov 13, 2009 at 1:33 PM
