Can a radiator leak transmission fluid without it getting into the engine coolant? Is the engine coolant ever red?
May 6, 2009 at 2:37 PM
KENHARRIS8
MEMBER
1 POST
the coolant in a saturn is red/orange.
Aug 9, 2011 at 7:23 PM
SATURNTECH9
CERTIFIED EXPERT
The dexcool is orange and yes it can leak transmission fluid with getting into the cool.Is it leaking right around the top transmission cooler line on the radiator if so you have cracked radiator and needs to be replaced.
Aug 9, 2011 at 7:54 PM
SATURNTECH9
CERTIFIED EXPERT
Is it leaking below the upper radiator by the upper transmission cooler line if so you need a new radiator thats a really common place for them to crack and leak.
