1994 Saturn SW2 Starter will not disingage after releasing
1994 SATURN SW2
105,000 MILES • 4 CYL • FWD • AUTOMATIC
AFFINITYLOU
This one should stump you. After starting engine, the starter shaft stays engaged after engine begins running (you can hear it doesn't release by the noise the starter makes). After turning ignition key off to kill engine, starter continues to turn engine over until you disconnect negative battery cable. After reconnecting battery to try again, sometimes the starter disengages ok on the first try, but will not on the second try. This problem started with original starter, continued with 2nd and 3rd replacement starter. Replaced ignition switch, no help. Tested purple wire which engages solenoid by turning start switch several times, 12 volts drops to zero each time I release switch, so switch works fine and circuit seems ok. HELP!
Oct 13, 2008 at 10:30 PM
BMRFIXIT
  • 19,053 POSTS
I would still check the starter
something wrong in and around it
disconnect the switch wire S terminal
and with key off jump the battery to the S terminal, starter should engage, remove the jump wire, starter should stop if not remove the starter and bench test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 14, 2008 at 6:43 AM
