1997 Saturn Station Wagon clutch / lack of power on take of
1997 SATURN STATION WAGON
230,000 MILES • 4 CYL • FWD • MANUAL
SBM11525
i have a 97 saturn that has been running ok the engine seems to have enough power and it sounds like it is running fine but it is getting so that i have to rev more to start going and it will only go to 50 mph could this be related to the need to replacce the clutch or do i have to replace the tranny, also is there a way to replace the clutch without removing the engine
Oct 20, 2010 at 10:12 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.So when your taking off you need more rpm"s?Also when you can only go a max speed of 50mph If you try to go faster does just the rpms go up and no speed increase?So you know you need a clutch?You don't have to remove the engine to replace the clutch you have to use a engine support to hold the engine up and remove the sub frame and transmission.
Oct 20, 2010 at 10:31 AM
