Thanks saturntech9 for the location. Found it. There is a clip underneath the module. Problem is there is a structure like bar where a ground is attached, which limits my hands from spreading the clip and removing the module. I'm not in possession of the replacement module (ordered it at a remaining dealer some 30 miles away and there is a week lead time) and don't want to ruin the existing module. Is there a trick to actually removing the module? Something to hold down the clip? Is the removal a straight pull out? Can I wiggle it out, sideways or vertically to remove it? There is another, small box-like fuse or relay/component directly on the modules 12 oclock; should I pull that one out first? I'm not confident I'm able to remove the module correctly because it is really like tight. And like I mentioned space to get my hands in it is at a premium. Thank you for your help in this. Get me through this and donating will be easy.
Nov 21, 2009 at 11:09 PM
